I took my 79 XS 1100 Special on a maiden voyage and the bike decided it had it in for me. I treated it so nice and rebuilt it with absolute care and cut no corners.
I was doing about 40MPH and the light ahead turned yellow so I decided to stop rather then go through the yellow. I laid decent on the front with a nice little on the rear brake, at this point the bike went into a extremely bad wobble. I have been riding for a long time and have felt slight wobble, that can be worked out with a tap of the rear brake or letting off the throttle. The wobble was the worst I have ever felt, and it kept getting worse. I let off the front brake and tried to tame the beast. I decelerated rapidly with wobble still in effect. I turned right still wobbling and was able to pull into a driveway where I had to check my pants. It wobbled all the way down to the stop. I gathered my strength and took it for a ride around the parking log. I was able to simulate the wobble by moving the handlebars, but not by the front brake. My guess is I was not going fast enough or braking hard enough.
After reading several posts on XS11.com and other forums I found there is a number of things I can do to keep this from happening again and that it is not unusual with these bikes. I have had 2 other XS11's in the past and never experienced wobble. Maybe just lucky.
I could not find a real reason mechanically as of why this happened, however I am making some changes.
Fork Brace by Tkat
Rebuilding the front shocks (need to find somebody to send these off to)
Rebuilding the Damper Triple Tree
New Tires
New Front Rotors
This should help!
Fork Brace by Tkat
New Tires
New Front Rotors
This should help!
