Hard cover for LEFT side?
Discussion in 'General Vetter Discussion' started by Larry Fine, Aug 17, 2015.
  1. Larry Fine
    Larry Fine Moderator
    Does anyone know whether there ever was a left-side hard cover for the WJ? I'm thinking of speaker options.
    I wonder how hard it would be to disassemble a right-side hard cover, heat it, and make it a left-side cover?
    Added: I changed the thread title to LEFT side.
    #1 Larry Fine, Aug 17, 2015
  2. AVetterXS
    Actually a great question Larry... Ill have to look closer at one.
  3. rob.lafady
    rob.lafady Vetter Aficionado
    Longview, WA
    I've never seen one...
  4. Larry Fine
    I'm still thinking about trying to soften one enough to flip it inside-out.
  5. brianinpa
    Me neither.
  6. AVetterXS
    That would be interesting. Are you thinking of heating it up?
  7. Larry Fine
    What else? I'd probably want to make a mirror-image mold to shape it to, or rather, over. I imagine it would be impossible to get it shaped right any other way.
  8. brianinpa
    One problem with using a right side cover on the left side is that the right side cover has no texture on the inside...
  9. Larry Fine
    I've considered that, and thought of covering both covers with a matching material.
  10. AVetterXS
    I am waiting for the prototype. Ill take mine medium rare please. :lurk
    • Old Old x 1
  11. brianinpa
    I have a right side cover that has a big hole in it where a stereo once resided... I think I have a contestant!
  12. Larry Fine
    Okay, you win. :D
    Let me know how hot for how long to heat it to make it pliable without liquefying it.
  13. AVetterXS
    :cheer I feel like a little girl! I can't wait. Biting nails.
  14. AVetterXS
  15. Larry Fine
  16. brianinpa
    Well... I looked high and I looked low. I'll be damned if I can find that cover, so what to do? Since I have about 5 of them, I picked the next best contestant (the one with the most holes in it...)
    If about 15 minutes using nothing but this (and a block of wood - that thing puts out a lot of HEAT on the fingers :mob):
    I turned one of these:
    Into this:
    From the side...
    The plastic was hot, so I set it aside to cool off for a while. More to follow, but you can see that it is possible.
  17. Larry Fine
    Excellent. I have a heat gun. The hard part now would be shaping it well. Trial and error seems tedious, but doesn't require making a mold. Maybe a sheet-metal pliers or vise-grip would make a good bending tool.[​IMG]
  18. brianinpa
    I am going to cut a piece of plywood the same shape as the opening and form it around that using everything I have.
  19. Larry Fine
    I hope you don't mean all your strength.
  20. brianinpa
    Nope. Tools....
