LED BULB replacement
Discussion in 'Vendors: Products & Services' started by michael_pickell, Apr 15, 2015.
  1. michael_pickell
    michael_pickell Learning the Ropes
    Neptune Township, New Jersey
    I wanted to change my blubs to LEDs.
    I found out that turn signals and flashers on old bikes use the current load of the incandescence bulbs to activate a thermal switch in the flasher / signal relay. LED's do not make sufficient load to trigger them. I replaced with that below a LED compatible Solid State Flasher EF32SS-R 2-Prong solid state turn-signal and hazard light flasher, suitable for 6 Volt and 12 Volt vehicles This is a solid state flasher: It uses a built-in transistor LED compatible Solid State Flasher EF32SS-R 2-Prong solid state turn-signal and hazard light flasher, suitable for 6 Volt and 12 Volt vehicles This is a solid state flasher: It uses a built-in transistor.
    • Useful Useful x 1
  2. AVetterXS
    Michael the link is broke.
  3. BeachedSquirrel
    BeachedSquirrel Vetter Aficionado
    Kansas
  4. AVetterXS
Users found this page by searching for:
  1. led flasher ef32ss r
