Material of headlight housing
dieter
Bavaria/Germany
Hi folks,
I've recently purchased a 7" LED insert to replace the old headlight insert. However, there is a little bir more room necessary. Easiest would be to use a heat gun - if the housing is some kind of thermoplastic.
Any ideas?
Best regards
Dieter
Andy52
Leamington Spa, England
#2
If you mean the main plastic shell of the fairing, it can be softened and bent with a heat gun and welded with a soldering iron. I haven't tried stretching the plastic with heat though.
Alan F.
Boston
neclassicmotoguys.freeforums.net
I did a little searching and a few years ago someone had cut a hole in the back of the headlight housing and thru the fairing to allow room for the heatsink on an H4 LED bulb, I didn't get the link though sorry.
I would wonder if there would be sufficient cooling airflow for the LED without venting through the headlight housing and fairing?
