Mohladissenter
Any diagrams of exploded cycle sounds clam shells and stereo arrangements? I can't seem to crack mine. Took the speakers out and all bolts I could see last night, trying to access the Sony Xr25 deck that isn't powering up, to no avail. The wiring all checks out (tested with voltmeter) and I can see all the fuses are good... save for one 3Amp fuse that is "pinched" outside of the cycle sounds shell behind the deck (I can see the wires and the in-line fuse in the gap between the windshield mount and the cycle sounds shell. I assume it shouldn't be "isolated" for any reason? Not sure why it's out there but I certainly can't get at it without removing the whole enclosure and radio.
Anyhow I cant get the dang radio to budge and I need to inspect that fuse to see if that is the sticking point. Not sure what is meant by "Remove the radio knobs, then the nuts from the shafts.". Perhaps I'm missing something. Is this on the radio unit itself? Like behind the knobs?
This is on a 81 GL1100 BTW. Thanks for your help!
