Rooster fairing
Discussion in 'Wanted: Motorcycles, Fairings & Accessories' started by Bladequarter, Feb 8, 2015.
  1. Bladequarter
    Bladequarter Learning the Ropes
    Dallas, Georgia
    Possibly Looking for a rooster fairing for a good price.radio and speakers not needed
    Look twice save a life, motorcycles are everywhere
  2. Larry Fine
    Larry Fine Moderator
    As the proud owner/operator of one (see avatar), I can attest to the right-size-ness and great looks of the Rooster, and wish you luck.
    Replacement windscreens are still available in several sizes and colors, if you find a body alone in decent shape.
    They occasionally pop up on the 'Bay. I recommend checking it daily, as well as searching your local and nearby Craig's List ads.
  3. AVetterXS
    I use Search Tempest for more of a wide range Craigslist search. Once you master it, it is very cool tool.
    http://www.searchtempest.com
    You will be surprised, but CR folks will ship for a few extra bucks. Considering that Craigslist is traditionally less expensive then eBay its a win win.
  4. Larry Fine
  5. Bladequarter
    Dallas, Georgia
    Thanks for the info guys
  6. brianinpa
    I think I paid $60.00 for mine ( I am going to have to find exactly what I paid for it because I don't remember. )
    They are a really robust fairing and easy to work with. If it is busted up, as long as the out shell is intact, it is easy to fix. Here is the thread where I fixed mine: http://www.vetterowners.com/threads/vetter-rooster-fairing.203/
    • Informative Informative x 1
  7. Italo Balbo
    Italo Balbo Grasshopper
    What mounting brackets did you use? Will national cycle brackets work, they are available on ebay but I don't know which ones will work.
  8. Larry Fine
    The Rooster didn't come with a mount in the usual sense. The front attached to the bike's headlight shell bolts with a pair of straight flat bars per side with holes in them in a scissors configuration, but I used the L-shaped turn-signal relocation brackets instead, turning them over so they extended inside the fairing instead of below it. Then, an up-side-down U-shaped round rod attached to the bottom of the fairing, which was affixed to a pair of handle-bar clamps.
    See: http://www.vetterowners.com/threads/rooster-installation-instructions-hardware.263/
    Also: https://www.ebay.com/itm/Vetter-Roo...d=332375177954&_trksid=p2047675.c100005.m1851
    And: https://www.ebay.com/itm/VINTAGE-VE...ash=item25df30fa90:g:kVsAAOSwBT9ZrGX6&vxp=mtr
  9. brianinpa
    I did use the National brackets to mount the fairing to the handle bars. To mount the fairing to the headlight, I had to get a little creative because the fairing almost doesn't fit the 1200 Goldwing. In the end, I made some flat bar stock work with hose clamps.
