Thanks, I am buying an SS and it is stripped, but it comes with the lower fairing extensions. And I have a IV & V already so I don't need to buy the lenses then. I am guessing the mount is the same??
Mounts are the same. The only thing you need to do before mounting them is to make sure the amber lenses are not separating from the chrome plated peaces behind them. If you see them lifting away 3M glue will stick them back in place so you will not lose the lenses as you ride. After I obtained my WJ IV I pulled the lens units and one of the amber lenses fell out as I was pulling it out of the fairing. The other one was separating as well. I removed the other lens so I could clean and shine the chrome reflectors behind the lenses and re-glue them with 3M glue.
