Well, here we are 9 days later after the accident. I am healing, slowly. Was able to replace the left side crash bar (had a spare). Was also able to do a decent repair to the fairing edge trim, using some leftover gold trim I had used to repair the other side after buying the bike. Did not come out quite as good as the other side, but it is serviceable. Have a left side mirror on order as well, as the orginal apparently hit the ground. There is s slight scuff to the clutch lever ball end, but mild enough that I can look past it. So the bike is healing, too. I even took it out for short spin up and down my dead-end block, and it seems to ride true and straight, so no obvious damage to the rims, forks, or frame. I feel a bit better, though still not sure how I wil deal with oncoming traffic moving forward (with abject terror?). Wife was less than pleased about my short trial run today, haw haw! Anyway, I am serious that I am more than a bit fearful that the "next time" I won't be as lucky.
ON EDIT: Uploaded a third photo (this one a closeup) showing my second attempt at fariing edge repair; I've decided I can live with it as is.
